Case Sealant......Pic
Would my case be okay if I used this sealant. I wanted to put the case together this weekend. I got some of this stuff, but I remember reading somewhere to not use silicone based sealants. Is there any other sealant that is recommended, that I can pick up from my local auto parts store?
Thanks, Rod ![]()
1974 914 2.0 D-Jet 2004 BMW R1150RT-P |
Permatex 3H Aviation Sealer would be better. Silicone can have too little wok time and if you don't get the cases buttoned up fast enough, they may leak, or worse, they may not come together all the way leaving your main bearings loose on the crank.
Milt, do they sell 3H Aviation sealer at local auto parts stores, if not where could I get some?
What about anerobic from a GM dealer, they use it in transmissions.
Won't dry until the parts are torqued together (might dry too well then though) |
Banned
Yamabond at the Yami dealer in the morning. It the same stuff as we use Three Bond 1104. Steve
I agree with Zeke, That is what is recommended by all the VW engine builders I have talked to and it is what I used on mine. Works great.
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
Banned
I used to use Curil k-2, But now 1104 is my sealant of choice thanks to Otto who showed me how well it works. Clean all the sealing surfaces with acetone or MEK.Steve
Where can you buy "Top Bond 1104"?????????? Not sure my FLAPS has it.
Ken
Anything worth doing is worth doing in excess Every silver lining has a cloud Assume Nothing |
Ken, you may be talking about "ThreeBond 1104" in a yellow package available at most motorcycle shops.
Steve is this the stuff? Mark
1985 Targa Carrera 1972 914 2.5L four, side shift 1987 944 2005 Husqvarna CR125 1980 YZ125G |
Banned
The Yami dealer Yamabond is the same stuff.Steve
Thanks,
Ken
Banned
YEP thats it. Steve
Steve is it Yamabond 4 (semi-drying) Yamaha # ACC-YAMAB-ON-D4
Mark
Steve,sorry I took to long to post Thank you Mark
Banned
It works great,Mark whats the specs on your 2.5? Steve
Steve it has been about 4 yr since the motor was done. It started as a 1.7l that was made into a 1.9l then a 2.2l est now it is close to 2.5 l in the 1.7 cases. Big crank counter weighted, Big cylinders maybe 103 or 105 big valves. Another engine builder in Orange County helped me and I am Very happy. You also helped me get some parts for the car. I will try to get the specs for you. Sorry I feel silly for not having all of the answers in my head. New baby will do that. I will call you during the week. Have a good weekend Mark
Thanks to all, I picked up a tube of Threebond 1104 from a Harley mechanic this morning.....
Thanks, Rod
Banned
I always had the feeling that the cases should be one piece ... maybe something like this http://www.pauter.com/super_pro.htm .
Now those engines are nice..........$$$$$
