davidl's Avatar
914-6 oil tank fitting holes
Hello all.
I am seeking the precise sizes for the various holes in the rear inner wing panel.. I wish to do this absolutely right!
I hope some kind soul can measure his own sixer for me!
david
Old 11-17-2003, 01:44 PM
kellzey's Avatar
Check the 914-6 conversion guide here on Pelican. The hole sizes are there!
http://www.pelicanparts.com/914/914-6_construction_kit/914-6_info_guide.htm
4" to 4.5" for the oil filter
2" for the breather hoses
2.5" for the filler neck
1.5" for the 2 hole return line holes.
Qarl
Old 11-17-2003, 02:11 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Are you using a factory or Valeos tank? Steve
Old 11-17-2003, 06:22 PM
davidl's Avatar
Hello, Steve.
I have the factoru tank, and I want the exact hole size as original if possible.
Unfortunately, the sizes given in the Conversion Guide are approximate..does anyone have exact numbers please?
Kind regards
Old 11-18-2003, 08:50 AM
Just happen to have the hole pattern sheet in front of me.
The sizes are .....from the fwd bottom, up & aft (i love the nautical stuff) 1.25, 4.0, 1.75 , 2.5.....that's the easy part.
There are 2 mounting holes of about .32.
As in real estate, location, location, location. The toughest one to locate is that first one....no convenient upset area locates the sucker.
A couple other pitfalls (did I tell ya I've BTDT?). Rubber grommets
for the mounting studs are needed. That lowerhardtolocate hole
is also used as a mount....it holds the bottom of the tank tight
to the inner wall. I came up with "something"... BF washer,
with rubber washers inside & out....all pinched by the metric to AN adaptor that I had to use....hay, it works.
You also have to pop an oval hole into the engine shelf to route the oil line to that lower hole......AND use some kinda grommet
in the oval sucker to protect the line...I used split fuel line.
The whole thing is a PITA. Enjoy.
JPIII
Early Boxster
Old 11-18-2003, 11:42 AM
