Fuel Tank Outlets with Carbs
Dumb Question...
Does one of the ports at the bottom of the fuel tanks get plugged, capped or ??? when a facet fuel pump is installed. This is prep. for installing Weber carbs.
Old 11-05-2004, 04:50 PM
OCD project capitan
BigD9146gt's Avatar
windlake, both will work. The one larger of the two ports is the out, and the smaller is the return. The out has a coper screen that helps keep large debris in your tank from going down the tubes, and it sticks about a half an inch into the tank. The smaller tube will also work, and its lower in the tank, allowing you to get a few more gallons of fuel before you run out. I've run both ways, just make sure you have a filter before your pump.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 11-05-2004, 05:37 PM
