weber designations
Hi,
Was wondering if anyone knows what the letter designation on weber carbs stand for if anything. For instance "IDA", or "DVG", etc. I have the haynes weber book and can look at the various carbs, but was wondering what the letter stand for? Thanks. Houston in Lousisiana |
To quote from HPBooks "Weber Carburetors" by Pat Braden:
The prefix always indicates the size of the throttle plate i.e. 40 DCOE is a 40mm throttle plate. The letters immediately following the prefix refer, in Italian, to the general type of carb. Only a few terms are consistent: "DC" means doppio corpo, or double-throat. "V" means verticale (vertical) and "O" means orizzontale (horizontal). The "I" in IDA seems to mean invertito, or inverted. Yet, there are no updraft, or inverted, Webers; the IDA is a downdraft. Other even less-consistent single-letter designations are: · E: Die cast carb · F: Ford (of Europe) or Ferrari (?) application · V: Carb with power valve · A: Water-operated automatic choke · G: Progressive rate Weber carb nomenclature is chaotic. The IDA may be 2-3 throats, and there is no choke at all. The "E" in DCOE indicates either a trapezoid bolt pattern (in some applications), or a rectangular pattern. The DCN fitted to the Lamborghini was a DCNL, but if fitted to a Ferrari, became a DCNF! Any questions? |
so what will the description of my 40idx or idf?
[This message has been edited by stelan (edited 01-15-2000).] |
A 40 IDF is just what it's called, a 40 IDF.
Sometimes, a cigar is just that; a cigar. |
| All times are GMT -8. The time now is 04:51 PM. |
