-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Which socket should I use to remove axle nut? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/140273-socket-should-i-use-remove-axle-nut.html)
Alfred1 12-18-2003 03:24 PM
Would the Sears 30mm, 12 point be ok or would this GM 30mm Deep 1/2'' Drive Axle Nut Socket be better. I don't really like 12 point sockets.
sean_V8_914 12-18-2003 03:52 PM
I recomend the 6 tp version and a 5 ft pipe or impact air wrench. I prefer the pipe, seems less brutal. If it is resistant, put a torch to it till it gets smokin hot
Alfred1 12-18-2003 04:11 PM
Five feet? I just bought a 25" breaker bar - won't that do it?
Dave at Pelican Parts 12-18-2003 04:16 PM
Sometimes. Maybe. If you're built like a tank...
Actually, removing the cotter pin and heating the nut up with a torch might make 25" a long enough lever, but I would have the "cheater" pipe ready just in case. Also, pounding on the back of the socket with a mallet (hit as if you were trying to drive the stub axle out) can help loosen things up sometimes as long as you are applying force at the same time.
--DD
sean_V8_914 12-18-2003 04:25 PM
I dont even mess around with all that. the 5 ft pipe makes easy work of VW flywheels, vw bug, bus and 914 axle nuts.; I even use the pipe to change tires (removal only) try is once and you'll give it a name. kinda like a pet
Stock93 12-18-2003 05:03 PM
3/4 in air impact wrenches are a great investment. Even the cheap ones I have used have put out quite a bit of torque.
John
sean_V8_914 12-18-2003 07:45 PM
Harbor freight and Sears offer an electric impact for those who lack compressor access
SteveStromberg 12-18-2003 07:58 PM
DD is correct ,Use a Cheater bar. Have the Biggest Guy you Know Lean on it, just pushing down not bouncing on it. Then Hit the Breaker Bar at the pivot point where the socket is attached. This should knock it lose.Steve
Alfred1 12-18-2003 08:02 PM
My brother's a powerlifter/accountant - maybe I'll get him to loosen it up for me.
red-beard 12-18-2003 08:22 PM
Originally posted by sean_V8_914
try it once and you'll give it a name. kinda like a pet
My was called my ****'n pipe. Cause I'd say "****" everything I pushed on it...
Acox914 12-18-2003 08:56 PM
i just got my dad a 7.5 amp electric half inch impact wrench. 240 lbs of torque baby!
jenmcd 12-19-2003 06:57 PM
240 ft/lbs??? After breaking 2 Snap-on 1/2" wrenches with 4 ft pipes attached to them, no way! A 3/4" drive Ingersall Rand impact with 1000 lbs of torque did the trick. Funny thing is that the drivers side came off without much effort. PO must have hauled some BIIIGG people around.
Keith
boogerboy72 12-20-2003 05:53 AM
wait, are yall talking aobut the nut that holds the rear axels on? Cause if yuo are, Me and my father could use some help geting it off. Ive read jsut to use a cheater bar and get a big guy to lean on it, but how do we keep the wheel from turning. We're thinking about building a rig for it. Then just get the guy whose gonna paint the car to break it off. Im pretty sure hes big enough, his hand covers 90% of my chest, and well....he right strong.
SteveStromberg 12-20-2003 08:04 AM
Put the car on the ground. Steve
boogerboy72 12-20-2003 09:31 AM
i knew that. Thanks man.
Jim Smolka 12-20-2003 10:29 AM
Step up to the 3/4" stuff. The good stuff (Snap-on, Mac, Matco) is nice but very $$$. Overseas stuff works OK.
Sears has some 3/4" stuff too.
mike95125 12-20-2003 11:49 AM
Ok, everybody
Ohm...heat, beat, repeat, heat, beat, repeat...ohm
The 914 mantra
Then cut the beyatch off
jcwade 12-20-2003 07:34 PM
Leave the wheel on the ground and you can turn it without any problem.
I must have been lucky, I took off both castle nuts with a 2 ft
breaker bar and a 30mm axle nut socket ($8.99 from Pep boys)
and didn't have any trouble. But I sure was expecting some after
reading these posts.
I hope you're luck is as good.
john
Jason Porter 12-22-2003 11:50 AM
I use a 2 ft. breaker bar on my axle nuts. But I can bench press 300 lbs....Come on now, admit it, how many of you would like to be young and stupid again?
Jason Porter 12-22-2003 11:55 AM
Also, IMHO, use a 6 point. More solid for the type of torque we're talking about.
karlp 12-22-2003 12:03 PM
I'm with Mike95125, cut it.
I beat it, heated it, beated it and had enough torque on it to spin the wheel on the ground.
2 minutes with a die grinder I'd cut a slot long way, not all the way through, then hammer and big chisel and split it.
Paid $6 for a new one at the local motorcycle shop.
Karl P
