Facet fuel pump
My car has sat in a dry enclosed garage for 14 years. It was converted to carbs and had a Facet fuel pump installed in the front trunk in the same spot as the original FI fuel pump. Now that I am getting the car back on the road do I need to be concerned about the pump having gone bad by just sitting abound for that long?
I would just replace the pump after a sit that long. The price range
varies like crazy on those facet pumps. I've seen them from $28-$90 for the same pump. Drain the gas tank too and check it for rust. Replace the fuel filter and get all of the old gas out of the fuel lines. Your carb(s) will most likely need a cleaning. |
grind weld build
14 years!!!!! I highly recomend changing EVERY rubber fuel hose. FIRE FIRE, warning, warning, danger Will Robinson, danger!!!
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
Thanks guys. Nobody with 914 likes to hear the word fire!!
If you're thinking you have to pay anywhere near $90 for a Facet, stop and buy something decent. That kind of money will buy a much better pump. Quieter and higher volume.
grind weld build
Milt is right. facet should go for $30 at Kragen, Pep Bboys, Checkers, Auto Zone. Holley blue, a much better unit goes for $50 at the same vendors. also Summit racing and PAW
Thats the rotary pump I bought, Its mounted in the engine bay and sometimes I really have to listen to hear if it running, well worth the money.
74 LE "Bumblebee" 03 Jetta Wagon |
