tire size
What size tires will fit Pedrini wheels?
Old 12-23-2003, 06:19 AM
Stock 165X15 but not very many brands available. Closest modern size readily available is 195/65x15. Might be able to use 205/60x15 but you could have to roll rear fender lip on one or both sides.
Old 12-23-2003, 08:33 AM
Member w/ Title Problems
Jason Porter's Avatar
My roommate runs Pedrinis w/Dunlop 195/60x15's. That's about the widest you can go with a good stiff sidewall. The Pedrini is the same dimension as the 2.0 Fuch alloy, and the 4-lug Mahle for that matter. I wouldn't go any wider than a 195, and flatter than a 60 or 65, as 55's are expensive, and 50's will turn your speedo into a wish list.
This is all IMHO of course.
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 12-23-2003, 03:06 PM
yoh!!!'s Avatar
Hi, I have Dunlop 195/55 15 on Mahle wheels. The speedo is about 5 to 10 % faster than the rest of the car. I have some very mild rubbing on the inside of the front wheelwell. There is enough space on my fenders to accoadate 205's. IIRC the 195/55 are on a variety of little passenger cars (e.g. my wife's protegeeee) I don't think they are expensive.
'74 Porsche 914 2.0l
'90 VW Vanagon 1.7l Diesel
Old 12-23-2003, 04:02 PM
195/55's are expensive when you get H-rated or higher.
Old 12-23-2003, 04:19 PM
914Ghost's Avatar
I run 205/60 on 2liter Fuchs on the back no problem,
195/60 front.
Its a good combo, because you get that .366" or so hot-rod rake.
Everyone notices.
And good mileage because its downhill everywhere I go.
Robert O
p.s. drinks are on me!!
Happy Holidays!!
If it aint broke.. ... ... .fix it anyway.
Old 12-23-2003, 10:59 PM
914Ghost's Avatar
Forgot to say I got all 4 of my tires for $70 NEW at a random auto swap here in Washington.
Good tires too. Nice and round.
Old 12-23-2003, 11:01 PM
yoh!!!'s Avatar
My Dunlop 195/55 15 are V (up to 150 miles/h) rated and I did not pay a lot... Check this link...
http://www.tirerack.com/tires/Compare1.jsp?startIndex=0&width=195%2F&ratio=55&diameter=15&search=true&pagelen=20&pagenum=1&pagemark=1&performance=MP&performance=UHP&performance=HP&x=17&y=5
Old 12-24-2003, 10:24 AM
mikester's Avatar
Send a message via AIM to mikester
I'm running a set of Bridgestone Potenzas, they are 185s and fit nicely of course...not very wide but not narrow at all.
Next time I might do 195s but I do like the look of the 185s - not too much tire for the wheel. though - I was walking away from the car the other day and I looked back and thought to myself - "Man...those are a bit narrow."
no biggie - speedos way off too.
-The Mikester
I heart Boobies
Old 12-24-2003, 11:32 AM
What is a .366 hotrod rake?
Old 12-25-2003, 09:01 PM
