throttle switch testing
Need some help . am trying to test throttle switch and need to know if i should take cover off and apply leads to paths or should i put the leads where the connector goes? have directions for doing the adjustment but am not getting a reading any where. am i doing something wrong or is the switch hosed. did not test in car as it is 10 degrees today.
thanks |
You don't have to pull off the cover, just unplug the plug. I haven't tested a 1.7 switch, but the wiring diagrams say to look for a "14" and a "17" on the housing of the switch. Those should tell you which pins get shorted together to tell the ECU that the throttle is closed.
--DD |
thanks dave, cover came off whilst carring it in the house and out of cold.
| All times are GMT -8. The time now is 11:43 AM. |
