-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   GC engine case ? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/143805-gc-engine-case.html)
cary 01-13-2004 03:25 PM
GC engine case ?
I have a GC xxxxxx engine case that I might use on my 2.0 rebuild. But after examining it, it doesn't have the lateral oil pressure relief piston above the #1 lifters.
What exactly does that piston do ? Will it be ok without it ?
Jake Raby 01-13-2004 03:51 PM
It may be a GE case..... the only engines that did not have the relief were Hydraulic from the factory
Dave at Pelican Parts 01-13-2004 03:58 PM
Actually, a lot of the 73+ 914 engines did not have that relief. Cary, your GC is from a 75-76 2.0 914 or a 76 912E.
--DD
Jake Raby 01-13-2004 04:15 PM
Never seen one yet that did not have the provision for it...... Even my 912E engine has it, and that case is exacting a GC for a 914.
Oh well, guess I'm not well informed on these engines!
cary 01-13-2004 04:28 PM
GC 003700 .............from memory here at work.
So I'm ok to proceed, I take it ?
Thanks for the great video, Jake. I'm going step by step.
Enjoying your smiling face ............... LOL
Dave at Pelican Parts 01-13-2004 09:34 PM
Full steam ahead...
--DD
Zeke 01-14-2004 09:28 AM
No, no, Jake. That's not what he said. It just isn't machined and the pressure relief valve installed. I have a GC case that I'm saving. It's just as Dave said. The boss is there, but no valve prep.
cary 01-14-2004 10:01 AM
Yep, boss is cast into the case. But not drilled and tapped.
