Name that part
Hi, Begging your wisdom. I bought my car disassembled (never again) and I am uncertain as to which
parts are 2.0. Please view and let me know which are the correct 2.0 parts and if I have the correct lower cooling guides. Many thanks! http://forums.pelicanparts.com/uploa...1075082867.jpg |
the only things i don't recognize as 2 liter are the 2 items on the left, the 2 lower ones. the lowest one is a sorta flat plate which i think is the plate that a 1.8L air cleaner box (inside is the air filter) mounts to. it has a bit of a twist so that one end mounts to the body and there should be a 13mm hole in the center to receive a bolt thru the air cleaner box. the one above that looks like it has 3 legs... no clue unless it's something to do with a 1.7. all the other looks like standard common engine tin for type IV which includes 2 liter
the 2 in the upper center are for the alternator, the lower one "looks right". the 2 upper right go under the cylinders, it looks like you have the correct ones they look similar but there are L and R sides. ps: hope that's not all the engine tin you have because there are alot more parts:( |
Thanks for the input. I was wondering about the alt. shroud. The top one has a bigger hole and is dished.
The upper left bits have a different bottom. one is flat and the other one has a sort of tab on the bottom. I am guessing I do not need either of the bits on the lower left. Any more clarification would be greatly appreciated. I want to get this stuff (and the bits I have figured out) to the powdercoater. |
The three legged thing on the left side is for an air cleaner box stand. Not sure what engine size, but this goes directly over the air plenum on the years where the air cleaner box mounted over the center of the engine (I've only seen pictures).
The 3 legged thing is the stand for a 1.7 aircleaner box.
Ok so for number 6 bottom IPL. Does the 2.0 have a large dished hole (upper in my pic) or a smaller flat
hole ( lower in my pic).? And for number 10 Upper IPL. does the bottom have an extra bit of material (as in the upper one in my pic) or a flat bottom (as lower one in my pic)? I really do appreciate the help. There are no part numbers on any of this an I didn't take it apart. |
| All times are GMT -8. The time now is 08:27 AM. |
