Volkswagen Bus Engine (1700cc) Will it fit?
I have a 1972 Volkswagen Transpoorter with a 1700 cc engine in it. I have heard that the 914 4 cylender engine is ver much the same as the Vw engine. My question is can i put my engine into a 914?
yes, it is the same... just weaker in the HP dept.
look here for exact difference. http://tunacan.net/t4/reference/case.htm
'72, now with a living, breathing 2056... |
Banned
Yes and No. the oil dipstick is in the wrong location, the fan will not have timming marks on it that you can read thur the hole in the fan shroud, The flywheel needs to be swapped for a 901 style. Steve
Plus its 67hp vs 80hp
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
forgot about the dipstick, I thought that was only the later ones.
And all the engine tin....?
You hafta change all the cooling tin AND exhaust of course..
If it aint broke.. ... ... .fix it anyway. |
with enough money, any engine can be put into a 914, but that's probably not really your question. some major differences between bus and 914 engines include the oil level dip stick (914's go straight up, buses go horizontally out the back) the manner in which oil is added (914's have an oil fill on top of the engine, buses sometimes have a tube that connects to the bottom rear of the case and the tube is accessed from the rear). late (80-83) air cooled vanagons have a different exhaust sealing surface on the head than earlier buses and 914s. i bet it costs just as much to rebuild a bus engine as it does to rebuild a 914 engine. search other sites particularily shoptalkforums, 914club among others as this topic occurs frequently.
and no, i don't think you need to do any welding if you have the correct parts.
73 914 restoration project 73 914 2.0 CIS #80 74 914 1.8L L-jet 83 911SC |
Shubox, where are you located. I am switching my engine and have 1.7 porsche stuff that you can use. Fan, tin, exhaust, etc.
Let me know. Mike
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me. -74 914 with 74 2.7 CIS -74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system. -74 BMW R90 Last edited by mike95125; 02-14-2004 at 02:18 PM.. |
Oh yeah, it'll fit.
I currently have a bus motor in my car. Truth be told, it's a bus case with 914 heads, stock 1.7 FI. etc. When I got the motor (lovingly ripped out of one of Redbeard's Iron Oxide Conversion experiments) it took me a bit to figure it out. It warnt exactly right. Whover had rebuilt or rebastardized the thing had covered the bus dipstick location with a plate and moved the stick to the top of the motor. They put a copper tube where the location of a normal 914 dipstick would be, but the tube is slightly too large a diameter for a dipstick the seat properly. They also used the original bus dipstick, which is about 2 inches shorter than the 914 stick. It wouldn't even touch the oil level! If you filled it to the level indicated, the car was waaayy overfilled. I suspect that it still has the bus cam, as the car seems a bit underpowered compared to my old motor. The power difference between the bus motor and the Porsche version is mostly a function of the cam and the fuel injection. The rest of the thing is identical. If I had to guess, I would say that I have lost about 5 hp due to the bus cam (the stock 914 FI is esential to making the thing behave properly. A bus makes all its torque much lower on the RPM curve.) I make up for it on the track by keeping the throttle nailed to the floorboard. Short answer: it'll fit. Once you move the dipstick, it's a straight bolt in operation. All the tin and other paraphernalia should just screw right to it.
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
Banned
BAP-Geon rebuild. It was a kind of Universal case that could be fitted to a 914 or a Bus. LC pistons and FI cam . They came with 914 dipsticks. Steve
