cv bolt
I've searched the archives with no luck.
I need to remove the shafts, what size is are the cv bolts?
Thanks.
'73.5 911T
'87 944S
'78 928
Old 01-31-2004, 02:24 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
you need a "triple square" 8mm (maybe 6mm). if you're lucky, you need an allen
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 01-31-2004, 03:20 PM
Thanks,
I'm confident an allen won't do for me.
'73.5 911T
'87 944S
'78 928
Old 01-31-2004, 03:29 PM
Isn't this the VW special tool?
'80 SC
Old 01-31-2004, 03:35 PM
http://www.pelicanparts.com/catalog/images/suspension/8mm_cv_socket.jpg
'80 SC
Old 01-31-2004, 03:51 PM
ratwell's Avatar
You might get one kind in the kit (8mm triple square) and have another on the car (6mm allen). Best to have both on hand.
$27 is a little expensive for the triple square tool. I'm sure it's nice but you can get a similar tool at the vw parts shop for $6.
Old 01-31-2004, 10:51 PM
Jim Smolka's Avatar
To remove the CV shafts from the car, obviously, remove the 8mm bolts that connect the inner CV joint to the tranny drive flange. As stated earlier, use the 12 point 8mm allen or the some have just the 6 point allen. Be sure to clean out any dirt/grease inside of the allen bolts. A pick and brake cleaner works great.
Once the CVs are loose from the tranny, use a 30mm socket to remove the nut inside of the wheel hub. It may be necessary to use a large breaker bar. Sometimes 3/4" stuff is needed. Once the nut is removed, then pull the CV shaft out. Place CV into soft jaw vice and seperate the outboard CV from the stub axle.
After the CVs are out, inspect the CV bolts. Replace as needed using 12.9 metric fastners. Also, install new CV gaskets to keep the grease inside of the CVs
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 02-01-2004, 03:52 AM
yousaidpoo's Avatar
Send a message via AIM to yousaidpoo
i found one at NAPA for about 4 bucks. also, when you get new cv bolts, they will most likely be allen.
"Real racers turn right too."
"When life goes flying by... Downshift."
Old 02-04-2004, 11:00 AM
tat2dphreak's Avatar
pepboys and your local FLAPS will have it... I bought a set of 4 sizes (wasn't sure which I needed) at pepboys for $10 I think
'72, now with a living, breathing 2056...
Old 02-04-2004, 11:49 AM
