TIV Cam/lifter test fixture
http://www.shoptalkforums.com/viewtopic.php?t=65255
its on my forum on the STF, its a longe detailed post but well worth the reading. I'm sick of myths
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com Last edited by Jake Raby; 02-16-2004 at 06:50 AM.. |
Electron slingin mechanic
the link did not work for me. I got an error msg "The topic or post you requested does not exist"
W.T.F...over?
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
Member w/ Title Problems
Jason Porter - 888-280-7799 ext 233 - jason@pelicanparts.com 1989 Chevy Silverado 3500 - 454TBI, 4x4, 8 gallons/mile |
ah, much better, thank ya'll
no problem...
Have you considered using a large electric motor to drive the system, as opposed to the 1700 cc TIV? Would make the system less complex and easier to manage.
The elctric motor will cost much more to power and will not be able to share the oil system to create such a true climate for the testing... It would take atleast a 30HP 3 phase motor to run this fixture, thats why the TIV is much more feasible. I can build it for 40 bucks- thats the cost of a set of valves and rings. used parts are just 20 feet away.
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
Good points, but - 30 HP? That much friction to drive the valve train and oil pump? I would have pegged it at around 10 HP or less, and used a 20 HP motor. Regardless, if you have the parts ready, it's a moot point. Looking forward to hearing about results from this setup, hope you feed it back to the suppliers and get them to clean up their acts.
Gene Berg did one for a TI engine.. They started with a 10HP motor and found that it was not enough to get any RPM on the fixture..
Mine is more involved, but much more up to date and covers more bases.
