-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   need brake caliper rebuild kit (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/150257-need-brake-caliper-rebuild-kit.html)
auh 02-24-2004 05:13 AM
My rear right caliper capilber sqeaks a lot and don't know where to find a rebuild kit.
Any idea on where to find one?
Thanks.
Adam
SGB 02-24-2004 07:43 AM
Squeeks or leaks?
Squeeks OK, leaks bad. PP sells rebuild kit. Read tech article on website, its a pretty big operation.
tat2dphreak 02-24-2004 08:15 AM
I did the rear rebuild... but not the complete way the article said, I did nothing with the parking brake, because that was working fine... the other part... is easy... just like the fronts brakes!
Dave at Pelican Parts 02-24-2004 08:33 AM
Oy! Did you really need to ask?? ;)
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg4.htm#item16
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg4.htm#item17
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg4.htm#item18
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg1.htm#item0
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg4.htm#item19
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg5.htm#item20
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg5.htm#item21
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_brakes_pg5.htm#item22
--DD
