Passenger Door Window Removal???
I've taken the door panel off. But I'm stumped on how to pull the window out? Can anyone assist? Thanks in advance.
Old 03-05-2000, 12:32 PM
Throughout production of the 914, there were two styles of window regulators-but for both you remove the window the same way.
1)at the top of the triangle window pillar, there is a black piece of plastic. Remove it by rolling the windo down a bit and removing the two screws on the rear side of it.
2)unroll the window till you can see the bracket that holds it to the regulator. This bracket is at the bottom of the window. UNSCREW the bracket (dont pull the window out of it) from the regulator, and lift the window out.
Note-if you have an early model-pre 73, then the window slides in the chrome pillar with four miny wheels. You will have to pull the window all the way up to get it out, but be careful not to lose the wheels-they arent held on but with a little grease.
Good Luck!
Ben
ihas@ucsu.colorado.edu
Old 03-05-2000, 06:31 PM
