yousaidpoo's Avatar
Send a message via AIM to yousaidpoo
Porsche Crest smoke in the engine bay
as the title suggests, with the engine running, there is a considerable amount of smoke coming into the engine bay on the driver's side. its coming up from the pipe that leads from the exhaust into the engine bay. also, i noticed that where the pipe connects to the exhaust pipes, there is smoke coming out of there too. anybody have any clue whats causing it? i am pretty sure its not oil leaking onto the exhaust from the heads because i've checked it out a few times, and the smoke is definately coming from inside the pipe
any help is much appreciated
"Real racers turn right too."
"When life goes flying by... Downshift."
Old 03-12-2004, 01:52 PM
mike_the_man's Avatar
It sounds like the smoke is coming out of the heat exchangers to me. Probably oil in the heat exchangers, unless I'm misunderstanding. What does it smell like?
Mike
74 914 2.0L
78 VW Gti
82 VW Rabbit
Old 03-12-2004, 01:54 PM
yousaidpoo's Avatar
it does kind of smell like oily smoke, but it doesnt have the telltale "blue haze" to it. never thought about oil being inside the heat exchangers, that is a good possibility
Old 03-12-2004, 01:56 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
oil leaking into heat exchangers thru the seams.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 03-12-2004, 02:45 PM
yousaidpoo's Avatar
cleaned out as much of the heat exchangers as i could get to w/o removal, and there was no smoke, but i didnt have time to actually drive it. will drive it tomorrow and give an update
Old 03-12-2004, 08:14 PM
Jim Smolka's Avatar
Look for leaks around the oil return tubes (push rod tubes)
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-13-2004, 02:45 AM
yousaidpoo's Avatar
it is indeed the pushrod tubes. evidently when i rebuilt the engine not too long ago, i pinched one or two of the o-rings, and it split. obviously it isnt sealing. luckily i have 4 sets of spare o-rings and 2 spare tubes lying around
Old 03-13-2004, 02:11 PM
calbrat's Avatar
Oil got into the heat exchangers during my rebuild. once I ran the car enough it went away. You guys are correct in the solution.
Visit My Blog: http://fromsteve.blogspot.com
1974 914/4 2.0
2006 Hummer H3
2005 Dakota
Old 03-14-2004, 09:24 AM
