Porsche Crest Weber accel. pump.
OK, i have gone through my hanes manual and either i am stupid (a possibility i never discount) or theres no adjustment provision for adjusting the accel pump on IDFs . Does one have to change the cam that accuates the pump?
Jeff Donnelly
92 325i
71 914 w/2.0 and webers (needs paint)
74 914 potential driver, or maybe parts car.
Old 03-24-2004, 03:52 PM
DDS DDS is offline
Change the accel. pump jet size.
On DCNFs you can move the pivot point of the lever that actuates the pump, change the cam, or change the pump jet. Try pierce manifolds for parts. They're VG.
Dave
-- Dave
'73 914, 2056 GT/SC done!
'69 Lotus Europa S2 - under resto.
pics at
http://www.syer.net
Old 03-25-2004, 04:22 AM
Yes, there's a jet for it. In the float bowl, as I recall. However, this almost never needs to be changed.
Old 03-25-2004, 06:54 AM
DDS DDS is offline
It's #12 in this picture. Not in the float bowl. It has two nozzles that squirt down the bores when the pump is operated. Same idea as on a DCNF.
http://www.piercemanifolds.com/44IDF.pdf
-- Dave
pics at
http://www.syer.net
Old 03-25-2004, 06:22 PM
THANKS
thanks for the advice. Guess i will be buying more jets.
Jeff Donnelly
92 325i
Old 03-25-2004, 10:25 PM
DDS DDS is offline
IIRC those pump jets aren't cheap, so be sure that's your problem.
-- Dave
pics at
http://www.syer.net
Old 03-26-2004, 03:50 AM
