John Rogers's Avatar
New Transmission Gears at the CA Speedway
I finally got a chance to see how my new six conversion would run with the correct gearing. This past weekend at the CA Speedway the M-S-V combo was great and I would enter the main straight at full throttle in third, shift to fourth about 200 yds onto the straight and into fifth before start/finish. At that time the 6800 RPM shift light would be lit. I got a glance at the speedo and decided I wouldn't check it anymore!!!! Saw Bernie there and thanks for the great picture from last year!
Old 03-22-2004, 10:08 PM
bernbomb914's Avatar
The pic was from sat. practice
Bernie
May all your shifts be true
Chrome Yellow 74 1.8 Beauty
black 74 1.8 project car
2002 Land Rover Disco
2002 Astro Van
32' motor home
Old 03-23-2004, 10:24 PM
2002 Astro Van
32' motor home
Old 03-23-2004, 10:27 PM
2002 Astro Van
32' motor home
Old 03-23-2004, 10:29 PM
2002 Astro Van
32' motor home
Old 03-23-2004, 10:31 PM
The silver #21 was a 4 cly 2L. Went like hell in practice
Bernie
2002 Astro Van
32' motor home
Old 03-23-2004, 10:34 PM
Stay away from my Member
campbellcj's Avatar
Hey John glad to hear it was a fun & safe weekend. I REALLY need to get out there with you guys one of these times.
I thought the speedway was a pretty high-speed track though (w/ the Nascar banking section)? I also have a V top gear in my car and depending on tires you're maxing at 118-130-ish, and that's assuming you will run the engine over 7000. I know at big Willow I am on the rev limiter and could easily pull 10-15mph more on the front straight.
I will need a big-track gearbox sooner or later I guess...
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 03-23-2004, 11:28 PM
PCA7GGR's Avatar
I have not seen Centerline wheels without holes in a while. Any problems with your brakes heating up?
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 03-24-2004, 07:34 AM
Thanks a million Bernie for the picts. Chris, the trade seems to be the lower torque that the high reving sixes have require the lower 4th and 5th gears so you can get up to top speed easily. At Willow the 2.0L cars do about 6500 RPM in turn 8 and tap the brakes slightly for 9 and do a down shift to 4th for some good acceleration for the front straight. I had "X" for high gear with the big 4 and it was too high as I could not get the six to push it. So far I have not had any issues with brake heating, but I do run ducts to the front and use BMW calipers front and rear with Axxis Metal Master pads f/r and so far they have lasted over a year with no issues?! Sometimes I think the solid aluminum wheels act as a nice big heat sink, but I have no way of knowing for sure.
Old 03-24-2004, 09:01 AM
I have an 1800 F prod that pushes an "X" gear perfectly for a fifth....
My street car also has an "X" fifth and loves it.
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 03-24-2004, 09:24 AM
Sorry for the confusion about the gears. The "X" was in the big 4 gearbox and did work perfectly. I was too high for the 2.0L six since the six doesn't make the torque until much higher RPMs than the 4 did. At Willow Springs I only had to shift once with that high torque four for turn 3, but I sure shift a lot more than that now........
Old 03-24-2004, 09:47 AM
campbellcj's Avatar
John at Willow I am at the rev limiter (7300) in the V 5th by the start finish line so I lose a lot of potential speed between there and 1. I tap and drop into 4th as you said for 9 but am back into 5th by pit exit.
When I get the cajones (and maybe a spoiler) I should be topped out in 8 as well. Last time I was too chicken to look at the tach/speedo but was not close to redline.
I do have very short tires though...I bet your slicks have significantly more rolling radius.
Also my engine is more like a 2.2T/S (a small port S) so the torque curve is slightly beefier. It pulls quite hard in 3rd and 4th.
Chris C.
Old 03-24-2004, 10:37 AM
