Acox914's Avatar
Send a message via AIM to Acox914
Caliper Cleaning
Hey guys,
i have some M calipers that im cleaning. i want to get them clean enough to the point where i can pain them red with caliper paint (yeah i know...ricer style ). they are still loaded (ie pistons and seals in bore, and bleader valve in place). i tried rubbing alcohol....not very effective. brake cleaner says it eats rubber so, that's out of the question.
-Aaron
"60% of the time, it works every time"
Old 03-15-2004, 04:56 PM
Zeke's Avatar
Scrub 'em with undiluted Simple Green.
Old 03-15-2004, 05:30 PM
Acox914's Avatar
will that hurt the rubber?
-Aaron
Old 03-15-2004, 05:43 PM
MXMARK's Avatar
will that hurt the rubber? I don't think so it will just leave a film on them. How about taking them apart and giving them a good cleaning. Just an idea. Mark
1985 Targa Carrera
1972 914 2.5L four, side shift
1987 944
2005 Husqvarna CR125
1980 YZ125G
Old 03-15-2004, 06:34 PM
grind weld build
sean_V8_914's Avatar
use heat. Hot soapy water will soften teh dirt, grease, grime and hardened brake muck.
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 03-15-2004, 07:18 PM
MXMARK's Avatar
Aaron, Maybe Dawn and make sure you flush out the fluild after and put new fluid in to keep the water out. Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 03-15-2004, 07:22 PM
grind weld build
Rice, rice, baby!
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-15-2004, 07:27 PM
grind weld build
urethane clear is brake-fluid proof. I tested it.
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-15-2004, 07:28 PM
Acox914's Avatar
what paint is that? (brand) and where did you buy it?
-Aaron
Old 03-15-2004, 07:48 PM
Zeke's Avatar
You can brush your teeth with Siimple Green. It won't hurt a thing except dirt.
Yeah, the hot water is a good idea. I thought anyone would use hot water to strat with, but what do I know?
Old 03-15-2004, 09:44 PM
grind weld build
Western brand Urethane. Krylon red. Mar-Hyde grey etching primer
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-15-2004, 10:04 PM
Acox914's Avatar
sean: you dint use specialty hi temp brake caliper paint? how have they held up thus far?
-Aaron
Old 03-17-2004, 06:05 PM
grind weld build
really well. 4 months without a blemish. Did I mention that the car is up on blocks
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-17-2004, 06:27 PM
grind weld build
contrary to popular myths, brake calipers do not get very hot. Rotors get hot. pads get hot. I did not paint those
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-17-2004, 06:29 PM
Acox914's Avatar
Hey, just a public thanks to MXMARK for putting my calipers in his solvent tank and cleaning them. Thanks,
Aaron
-Aaron
Old 03-22-2004, 07:57 PM
grind weld build
did the solvent alone get them clean?
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-22-2004, 08:04 PM
MXMARK's Avatar
Aaron, It was nice meeting you and any time. Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 03-22-2004, 08:15 PM
MXMARK's Avatar
Sean, Wire brush and solvent and a little bit of scubbing. Be careful around the piston bores.
Aaron, Please clean the solvent off with Dawn, hot water and Contact cleaner Then repeat. Check after install to make sure center orings are ok or replace center orings. Contact cleaner/brake fluid can eat orings. some dirt may be in center passages make sure you blow them off with air after and blow air in the passages to get them clean.
Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 03-22-2004, 08:23 PM
grind weld build
Warning!!! Actung!!!
all petroleum residue must be washed away wwith alcohol prior to assembly. The petrol attacks your new seals
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-22-2004, 08:40 PM
Acox914's Avatar
Mark
yep...washed the solvent off and dis some scrubbing when i got home.... blew out passages with air compressor. new rebuild kits arrived via fedex today, so i have something to do this weekend. thanks again for the help, and nice meeting you.
Aaron
-Aaron
Old 03-23-2004, 02:40 PM
