lmcchesney's Avatar
Conner weight adjustments with Knoi special D's
Continued progress.
Set up is Boge X-50's front with poly bushings and 22mm Wiltmeister sway bar. Roll cage full with good longitudinal.
Rear with poly bushings, 180# springs and Koni special D's adjustable gas shocks (adjustable damping).
Front weights adjusted with torsion bars. But rear shocks do not have an adjustable perch.
Is there a way to convert the Koni's to an adjustable peach?
Thanks,
L. McChesney
Old 04-04-2004, 10:03 AM
MXMARK's Avatar
I have Preload or height adjusters on the rear. They are Koni Yellows with the stop and then threaded collar fits over the shaft with an adjuster nut that has a locking bolt. Maybe our host has them if net if not then maybe they can get them. I got mine from another vendor. I hope this helps. Mark
1985 Targa Carrera
1972 914 2.5L four, side shift
1987 944
2005 Husqvarna CR125
1980 YZ125G
Old 04-04-2004, 10:55 AM
