i put some #s on the pic of the oil temp gauge. can anyone tell me the degrees that should be in the place of this #s please? if i'll put a gauge with #s, how hot is(the oil) too hot? thanks |
Member w/ Title Problems
I'd recommend dropping the sender in boiling water. That's around 212 F. That's almost the right running temp.
2023 Ford F-150 Platinum 5.0 Coyote FX4 2019 Toyota Sienna XLE AWD Metal Building Erector, Recovering Porsche Guy |
I can give you a ballpark, 170-200F is about 1/4" spread in the middle of the white part. I can post a picture later if you want. I put some cal. marks on mine since I'm using it for water temp. I'd assume oil temps could run higher, my guess the red starts at about 250 or so.
914 Geek
Of course, that assumes you have the same gauge and sender as the original poster. Which is not always a valid assumption...
The short version is, do the calibration yourself. Dunk the sender in boiling water and see where the needle goes. (Remember to ground the sender.) A camp stove is good for this. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
True, there are different VDO temp gauges. After looking at mine tonight my red line is further to the right, so ignore the numbers I posted. You'll have to do the boiling water method and candy or digital thermometer for some calibrated temp ticks. If they are even spaced below boiling point of water (like at 190, 200, 210) you could probably extrapolate a few temps above boiling point. I used a digital meter and could have heated up some oil for the sender but thought too dangerous.
RETIRED
Junk the gauge and sender...buy a new one. They were inaccurate when new and are none the better for the age.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
