-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Shutter at take-off (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1601-shutter-take-off.html)
joncdeke 03-24-2000 11:16 AM
Shutter at take-off
I can feel a lot of shutter when I first release the clutch in first gear. The whole clutch assembly has just been replaced, as well as, both the motor and transmission mounts. Any ideas as what I should check next?
Thanks!
Conrad W Peden 03-24-2000 03:17 PM
Was the plastic ball cup in the T/O bearing arm replaced. This caused mine to shudder.
Perhaps the cable tube in coming/breaking loose.
Conrad Peden
72 L20E + 1 dent
73 L20E in resto. soon to be raced-o http://members.rennlist.com/a914lover
a914lover@sprint.ca
iustasail 03-27-2000 08:32 AM
Did you have the flywheel resurfaced?
If not then the problem is that the flywheel will inevitably have ridges in it and will contact the new disk not all at once thus chattering.
The good news is that it should go away after a little use.
Even a totally new setup can chatter until it's worn in
Joe Bob 03-27-2000 08:41 AM
Did you put in a modified or racing clutch? The hot rodder versions have less springs or none at all in the disc. They hook up quicker but shudder at low speeds....
