atlporsche's Avatar
Efi?
what do you guys do for a return line if you've gone to an electronic fuel injection setup? do you even run one? or do you add a surge tank and just vent back to a common vent line?
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 04-28-2004, 10:50 AM
Puny Bird
Mark Henry's Avatar
The stock return line.
You MUST use one.
Even with a surge tank you need a return, but you can use a carb pump to the tank (FI pump to the engine). Yes 2 pumps.
Because the stock 914 fuel tank has a surge ring, you don't need a surge tank, unless your running a fuel cell or your on vapors all the time.
Old 04-28-2004, 01:11 PM
