-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 valve spring compressor tool (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/161029-914-valve-spring-compressor-tool.html)
Penna914 05-01-2004 12:12 PM
Does anyone know where I can find a valve spring compressor tool or can I use the tool designed for a type 1 or type2 engine.
ejm914 05-02-2004 02:57 AM
The spacing on a T1 valve spring fixture is wrong for T4 heads. Here's what the factory tool for T4 heads looks like. Most any of the "C" clamp style tools will do the job.
http://forums.pelicanparts.com/uploa...1083495189.jpg
eki912 05-02-2004 07:23 AM
I tried with my friends c-clamp , did not work.The reach was the problem.Atleast on his tool.I could not compress the springs , without first touching the edge of the head.
Bought a really simple one from SEARS.Universal type.Cost about 12 $.That will compress with a threaded piece , hooks under the spring.Worked OK , little fiddly though.....
eki
