' 75 1.8 Heavy "bucking" at high RPM
My ' 75 bucks hard at 3500 rpm. Just when I am ready to get on it the jerking begins. Then I get pissed. Please help . Thanks, Pete
Pete - When was the last time you replaced the fuel filter? I'd check that first.
Peter,
Another consideration is the TPS (throttle position switch). While you're checking the fuel filter (as Guy suggested), I'd also check the fuel pressure to see if its in spec. Have fun,
Gerard 74-914 White - Soon to be a custom 3.2L Six ![]() ![]() ![]() |
grind weld build
Points? condenser? Fuel filter! allwaays check the simple cheaaap stuff first
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
