iamchappy's Avatar
Clutch slip in the 914 turbo carrera
I am using the stage 2- 228mm heavy duty kennedy clutch - pressure plate with the 3.0 turbo and 901 tranny, the clutch slips a little when the boost kicks in, revs up a little then drops as the clutch finally bites in. The car is still accelerating and moving out while it is slipping. should I upgrade to a stronger setup or should I consider the slip a good thing in regards to helping the 901 cope with the torque surge. What do V8 guys with over 300hp and a 901 use.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 07-14-2004, 08:44 PM
I'm using the KEP stage III 9" clutch and have not experienced any slip.
Old 07-14-2004, 08:52 PM
iamchappy's Avatar
Guy, are you still using it with the 901.
87 924S
Lexus SC400
Lexus LS400
Old 07-14-2004, 09:12 PM
Yes. I avoid burnouts. Let it hook up and go. Quickly run out of gears with no detectable slip.
Old 07-15-2004, 07:31 AM
iamchappy's Avatar
When I purchase the stage 2 for the 3.0, a turbo addition wasn't even a thought. Stage 3 it is. Hows the engagement.
87 924S
Lexus SC400
Lexus LS400
Old 07-15-2004, 08:37 AM
Hey! Nice Rack! "Celette"
rich's Avatar
I need to think about upgrading a better pressure plate. I have a 6 paddle kevlar clutch disc with a stock pressure plate. I've slipped the disc a couple of times and had the engine rev as it slipped. But I think mine is related to the clamping force of the stock pressure plate. In my case, I'd rather slip the disc once in a while. I'm still runnung the 901. The up side with the kevlar as I understand is it gets sticky when it heats up. Tends to grab better. I was worried about getting the kevlar. Thought it would be hard to drive but it acts like a stock clutch.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 07-18-2004, 09:42 PM
