-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Anyone using the Ignitor II fom Pertronix? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/165036-anyone-using-ignitor-ii-fom-pertronix.html)
Alfred1 05-27-2004 12:00 PM
I'm assuming that the "91847A" unit is the correct one for our cars?
http://www3.telus.net/public/alpine6...istributor.jpg
http://www3.telus.net/public/alpine6...pplication.jpg
Rouser 05-27-2004 01:08 PM
Don't know anyone who's using the "II," so you'd be the first.
Anyone who's running an Ignitor is using the original "I."
http://www.pelicanparts.com/pmpre/im...WavingFlag.gif
http://www.pelicanparts.com/pmpre/images/Rouser/GWB.jpg
http://www.danasoft.com/vipersig.jpg
Dave at Pelican Parts 05-27-2004 01:52 PM
The applications listed (050, 009) are non-vacuum distributors. You may wind up having to grind things to clear the vacuum advance/retard arm. People had to do that with the original Pertronix for a while, before a revised version that had more clearance came out.
--DD
robinaube 07-18-2004 06:34 PM
Alfred,
Did you end up trying one of the new Ignitor II's? My Ignitor module just died and I need to order a replacement. The features in the new generation sound good but I'm hesitant to order one if its not going to fit.
Alfred1 07-18-2004 06:56 PM
Rob, I haven't tried the Ignitor II yet but check out what John from aircooled.net wrote in this thread.
there are 5 different "blue coils" bobby, not 2. I could sell the cheapies for $10ea and make money, then sell lots of points or pertronix/compufires after they burn up too! But that's not my style.
Having the wrong coil might explain a lot of the Pertronix failures.
Bowman74 07-18-2004 07:51 PM
That's the one that I'm running on a 009 in my Karmann Ghia. It works great. Make sure you get the Ignitor II coil to go with it. That will ensure that you get enough spark.
Thanks,
Kevin
Joe Bob 07-19-2004 07:23 AM
Make sure you have qan extra set of points when it fails on you in the middle of nowhere.
I'm Crane optical trigger fan. Petronix is a fishing lure if you ask me....
