-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   ground strap, where does it go?? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/165572-ground-strap-where-does-go.html)
24flys 05-31-2004 10:49 AM
hey guys, i got my car running but i found a groundstrap that is not hooked up. it is next to my relay board. any ideas where this goes. it was covered with black plastic. it hasn't been hooked up for years.http://forums.pelicanparts.com/uploa...1086025744.jpg
Dave at Pelican Parts 05-31-2004 10:52 AM
It doesn't. It's an add-on by some previous owner or mechanic.
The stock ground strap goes from a bolt on the end of the transmission to a stud on the bottom of the rear trunk floor. There's another ground that goes from the right side of the engine bay to the battery ground terminal, but that's it.
Sometimes people add another ground point from the engine to the battery. I haven't seen one running to the other side of the car before... Perhaps the ground point under the relay board was rusty or had problems of some kind?
--DD
24flys 05-31-2004 11:09 AM
thanks dave.
scotty
