-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   What is this? Need Your Help. (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/165691-what-need-your-help.html)
MLedesma 06-01-2004 09:03 AM
I was in the middle of converting to 5 lug, and was pulling the hub and stub axle from the donor car, when I realized that the stub axles I have are much larger than my others. I don't know if they are 914-6 stub axles (as the donor car is an original six), or if they are from something else (perhaps 911). They have 28 splines. Thanks for your help. Here are some comparison shots the 914/4 is on the left.http://forums.pelicanparts.com/uploa...1086105756.jpg
MLedesma 06-01-2004 09:05 AM
One more picture.
http://forums.pelicanparts.com/uploa...1086105892.jpg
Dave at Pelican Parts 06-01-2004 02:02 PM
I believe that 914-6 stubs are the same diameter as 914-4 ones. I'm not sure what you have there...
--DD
BURN-BROS 06-01-2004 02:40 PM
Maybe that is an SC or a 930 stub axle. It looks like it has been clearanced to fit. Keep us posted, I didn't think that they would fit.
Conrad W Peden 06-01-2004 05:08 PM
Is it me, or do those look like they have 6 bolt holes?
MLedesma 06-01-2004 07:40 PM
It does look like there are 6 holes, but there are only 4, with two holes for pins.
I am wondering what will actually bolt up to these. I could not find any part numbers, only some unreadable stampings.
Matt
Conrad W Peden 06-03-2004 01:12 PM
Brain Fart. I was thinkin those were hubs!
philinjax 06-03-2004 02:25 PM
Differential output flanges.
Phil
mike95125 06-03-2004 05:57 PM
Bus?
MLedesma 06-03-2004 08:01 PM
I don't think that they are differential flanges or from a bus. I took them off of a 914/6 race car and removed them from the 5 lug hubs. If a bus has the same amount of splines (28) then they could be from a bus.
philinjax 06-04-2004 04:36 AM
Yes, you're correct, I just looked at a 901 differential flange and it is quite small compared to wheel hubs.
Phil
MLedesma 06-04-2004 04:07 PM
I am guessing that these might be 930 hubs. Does anybody have some 930 hubs or know the dimensions and number of splines so that I might be able to compare?
Matt
BURN-BROS 06-04-2004 04:18 PM
Post in the 911 forum, they will set you straight.
