 Timing troubles
		I am the person who posted a question about changing my distributor from the Bosch 009 to the stock vacuum advance unit.  I am running the standard L-Jet FI.  I installed a stock unit, left the vacuum connections disconnected, and timed the ignition to the recommended 7.5 degrees BTDC at 900 RPM.  I then ran a hose from the throttle body to the "backside" of the vacuum advance unit (the larger stub).  I had the engine running and when I connected the line, the engine backfired immediately.  When I pulled it off, it idled fine.  What did I do wrong??  Also, I have looked at the hose diagrams on this site and it looks like everything else is correct.  When I put my finger on the end of the hose coming from the throttle body, there appears to be a lot of vacuum at 900 RPM.  Is this normal??
 The fitting that points back toward the distributor body should be vacuum retard.  This should be hooked to a line that gets a vacuum when the throttle is closed.  Sounds like it is, which is good.
	Does the diaphragm leak? Pull a vacuum on the retard port and see if it holds. Use a mity-vac if you can get your hands on one, or other good source of vacuum. Sucking on the hose might find a really bad leak... See what happens to the timing with and without the hose connected. Does it retard? By a lot or a little? You'll need to use your timing light for this test. --DD  |
| All times are GMT -8. The time now is 12:57 AM. |
