Banned
Torsion Bar and Stock fuel tank??
I recently bought a 914 race car and will be turning it back into a streetable car. It has 911T front suspension including a 19mm torsion bar. This bar runs across where the stock fuel tank goes (at the bottom) but the fuel tank is not installed there because a Fuel Safe fuel cell is in the front trunk [for sale btw]. I'll be putting a stock tank back in but will it fit with the torsion bar in place??
Doug C. |
Doug, as long as the swaybar was installed in the stock location(you can see the bosses where it mounts thru the body)the tank will fit. The early 914s came with this set-up as an option.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
