-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   swapping CA 1.7 Pistons for higher compression 1.7 pistons (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/167615-swapping-ca-1-7-pistons-higher-compression-1-7-pistons.html)
Jared at Pelican Parts 06-14-2004 09:16 AM
Going to have the motor out in the near future, would like to get a bit more power. Was curious if I'd have to susbtansially have to re-adjust the pressure sensor in order to make the domed 1.7 pistons from non-CA cars work....
Dave at Pelican Parts 06-14-2004 09:36 AM
Check your parts listing. I believe that the same MPS was used for both the CA-spec EB motor, and the "everywhere else"-spec EA motor.
Though with all of the D-jet systems, you may be able to get things to run a bit better if you take the time to fiddle with the MPS. But you'll need a dyno with WBO2 capability, or a WBO2 meter of your own and a lot of road time.
--DD
