-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Problem with distributor? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/169974-problem-distributor.html)
andyu911 06-28-2004 10:53 PM
Finally, I got my '73 2.0 fired again. But I notice the distributor shakes a lot when cold. It's kind of like swirl motion. What's the cause? I checked few time and make sure the cap is fit and tight. Also, the idle speed is above normal (1500rpm). I checked the TPS and it didn't help. Any advice?
Bleyseng 06-29-2004 06:24 AM
Take the cap off, can you move the dizzy shaft back and forth? If so the dizzy needs to be rebushed as its worn out. Have it rebuilt or find a rebuilt one.
Geoff
andyu911 06-29-2004 08:40 AM
Thanks, Geoff. I'll take a look today.
914GT 06-29-2004 08:50 AM
If the whole distributor body is moving sounds like it's just not clamped down tight.
