-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Thermostat return spring / diverter shaft ? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/170423-thermostat-return-spring-diverter-shaft.html)
Scooter311 07-01-2004 10:33 AM
Hey Folks, thought I'd throw one more out there -
Anyone have a pic / description of how it's supposed to be hooked up? Example - spring goes under or over the case tab, and does the tab on the shaft (where you clamp the cable) face up or down when hot?
Muchos,
Jeff
:cool:
porsche914blue 07-01-2004 11:35 AM
I don't have any pictures of the setup but the tab where the thermostat wire is should be down when the engine is cold (cooling flaps closed). As the thermostat warms up it expands and the tab will go up (which opens the cooling flaps). Hope that helps.
Scooter311 07-01-2004 12:59 PM
Got it, thanks a lot. I searched but for some reason I was entering it wrong - then I used your "Cooling flaps" and a bazillion posts came up, with pix even!
Cheers,
Jeff
