fuel injectors
i would like to know if there is any differance in the fuel injectors used by the l-jet than the d-jet fuel injectoin systems
RETIRED
Yep....L-Jet has blue coded ones...2.0 has Green....1.7 has yellow, I think...
The flow rate is diferent, also the 73-74 2.0L are different than the 75-76. the later ones are a lot more money if nothing else.
I've heard the L-Jet injectors have a different resistence in the coil winding. So I wouldn't mix L-Jet injectors with a D-Jet system. I did try it once (in my youth) but I never got that 914 working with that set-up (found out later I timed the valves wrong) but it didn't SEEM to hurt the D-Jet brain. |
