-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   center console (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1709-center-console.html)
sharky914 04-29-2000 05:58 AM
center console
What is the proper way to connect the oil temp gauge from center console? (wirering) I have a 1970. ...thanks
mejulihn 04-29-2000 07:57 PM
Check out the PP tech article on "Installing a Center Console" at the address below. It has great info and includes wiring diagrams. The article says the 914 came "pre-wired" for the center console gauges from '73 on. So you may have to find the right wire in the tunnel on your '70. Good luck!
http://www.pelicanparts.com/techarticles/914_center_console/914_center_console.htm
