Fuel Pumps
What fuel pumps are you guys running with carbs?? I have (had) and el-cheapo autozon unit on mine and it went south today. What is a good one?? I had mine mounted in the bottom of the engine bay. That was a bad idea. I think the heat killed it.
Old 07-14-2004, 04:29 PM
SGB SGB is offline
SGB's Avatar
Pelican sells an excellent one for about $50. I haven't looked it back up for reference here, but it has performed without hitch since I replaced my Facet pump about a year ago. It's quiet, easy to mount, and from our favorite supplier.
-Scott
My gallery page
Old 07-14-2004, 05:57 PM
where are you guys mounting them up front by the tank or in back?? I would think up front would be better.
Old 07-14-2004, 06:08 PM
SGB SGB is offline
SGB's Avatar
Up front, with the filter, next to the spare.
-Scott
My gallery page
Old 07-14-2004, 06:20 PM
Member w/ Title Problems
Jason Porter's Avatar
I run a Holley. It's a big blue crazy NASCAR pump, rated up to 90psi, but I had to have one redneck part in my car, or I couldn't live with myself.
It's sprung down to 4psi, and it's beautiful.
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 07-17-2004, 02:06 AM
ruddyboys's Avatar
I had a facet under the gas tank, way to loud. When it went bad I had to pull the whole gas tank out to get at it.I replaced it with a rotary syle from CB, can hardly even hear it. I also decided to mount it under the engine, the thought of having to pull the gas tank out again really doesn't appeal to me. Also I mounted a glass filter in front of the pump, under the tank you can't check it out or replace them when you need to easily. Some mount the pump in the front trunk, the thought of having a fuel leak where I could have a suitcase or something other did not seem good either.
74 LE "Bumblebee"
03 Jetta Wagon
Old 07-17-2004, 06:16 AM
mounting the cb rotary in this spot works pretty well.
Old 07-17-2004, 08:44 AM
