Questions about Type4 gasket kit
I had some questions about the Type 4 gasket kits. I thought I'd ask in this forum instead of a direct e-mail to Pelican since some others might be interested as well. Specifically I'm interested in the 2.0 version, but these questions apply to all Type 4 versions:
1. Are the pushrod tube seals that come with the kit Viton seals (the good ones)? 2. Does the kit come with the intake runner isolator blocks (with built-in gaskets) or just some gaskets to reseal your existing blocks? The picture shown in the online catalog makes it look like just some paper gaskets, but I had thought that it should come with the new isolator blocks. 3. Does the kit come with new case vibration dampeners (021-101-107)? These are the plastic cylindrical shaped parts that are installed on the 6 main case bolts between the case halves. Thanks in advance Demick |
1. No. The Viton seals are sold seperately, and can be purchased by calling me at Pelican, and I'll make sure you get hooked up.
2. They come with the big thick Bake-a-lite intake manifold gaskets. I assume that's what you're referring to. Let me know if you need a diagram, or email me for some pics. 3. Yes. |
Thanks Jason. Exactly what I needed. I'll throw a set of Viton seals in with my order as well.
Demick |
Regarding the viton seals. In the online catalog, you list the regular and the viton push rod tube seals. Then you list a complete kit of 16 seals (PEL-CYL-PTSET), but don't specify whether they are regular or viton. If I order PEL-CYL-PTSET, do I get Viton, or do I need to order the viton seals individually?
Thanks Demick |
Individually. Let me know if you need any help.
| All times are GMT -8. The time now is 07:33 PM. |
