Idle won't come down!
Ok I have a 73 2.0, FI, everything stock. It starts up fine & idles fine. But when I accelerate the idle won't come down unless I tap the gas pedal. Does anyone have any suggestions? Thanks in advance.
Old 05-18-2000, 08:32 AM
Germain's Avatar
Im guessing that 1 of 2 things is happening.
1 - the spring for the TB is no longer functioning correctly.
2 - The cable for the acc is getting stuck
I dont see how this could be a F.I. issue unless is the deaccel valve. To test this, try pinching off the hoses so no air flows through the valve next time it happens.
Good Luck
Old 05-18-2000, 09:00 AM
Ok guys, I sealed off the small hose on the decel valve but it didn't change anything. Or do I need to do it to all 3 hoses?
Old 05-18-2000, 01:11 PM
