lmcchesney's Avatar
Distributor points wire
I'm having a mental block. Does the green wire from the distributor connect to the negative or positive side of the coil?
Thanks,
L. McC
Old 08-11-2004, 04:23 PM
Dist Points Wire
Coil negative. HTH.
Old 08-11-2004, 05:10 PM
Negative. The points (or points replacement device) grounds the coil.
Old 08-11-2004, 06:21 PM
