2.0 FI Question
I am currently installing a 73 2.0 FI ingine into my 72 914. Opon test fitting the air cleaner it appears that there may be a part missing. Is there anything suposed to go between the throttle body and the opening on the cleaner assembly? There is a noticable size difference between the two pieces, and i am sure there needs to be a tight fit here........
Thanks Ben |
You're right. There is a rubber adapter that mounts to the throttle body, and is held in place with a band-type clamp.
I thought that I'd be able to take a quick look through the PP site, and find the part number(s) for you, but I wasn't able to find it/them. If you give Tom @ PP a call, I'm sure that he'll know exactly what you need. You might even be able to locate a good used one if you post a "wanted" ad on the PP site or the 914 club website. Good luck. Howard |
| All times are GMT -8. The time now is 02:37 AM. |
