lmcchesney's Avatar
Engine harness diagram
I'm not sure I labeled my engine harness correctly.
I also can't seem to find what number connector goes to what sensor/connector. Is this correct?
1-green/red- tem sensor #2
2- gray/red- thermoswitch
3-green/blk-?
4-gray/red-thermoswitch
5-Black/violet-coil
6-yellow-?
7-Black/red-oil sensor?
8- void
9- void
10 - connected to pole 11
12-white-?
I do not have a connector for my auxilary air.
Thanks,
L. McC
Old 08-06-2004, 08:14 AM
the yellow wire goes to the starter solenoid.
the white wire goes to teh aux air regulator.
I can give you more detail if you tell me the year and engine.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 08-06-2004, 08:44 AM
lmcchesney's Avatar
The harness I believe is a 72. The engine is a modified 1.7 with an EA case. The D-jet FI system is a 74. You know, the usual Frakenstien 914.
L. McC
Old 08-06-2004, 09:22 AM
Pin #1 Green with a red tracer. Oil pressure switch.
Pin #2 Grey with a red (?) tracer Back up light switch
Pin #3 Green with a black tracer Oil Temp indicator (optional)
Pin #4 Grey with a red (?) tracer Back up light switch.
Pin #5 Black with a pruple tracer Coil Negative (tach lead)
Pin #6 Yellow Starter
Pin #7 Black with a Red tracer Coil Positive.
Pin #8 No connection
Pin #9 No connection
Pin #11 Green Heater Blower
Pin #12 White Supplementary air valve
Hope that helps!
Clay Perrine
95 BMW 540i (Inga)
Old 08-06-2004, 09:41 AM
lmcchesney's Avatar
Thanks Clay,
That helps alot.
L. McC
Old 08-06-2004, 10:43 AM
