-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Swaybar Bushing install (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/176559-swaybar-bushing-install.html)
schosh 08-08-2004 05:03 AM
Are there any tricks to installing the nylon bushings used on the stock rear sway bars on a 76. At first glance it looks like an impossible fit. I verified that the parts I recieved form Pelican are the same size as the reminants I pulled out of the dogbone. Thanks in advance
Bill
Kevin Powers 08-08-2004 07:44 AM
place them in some HOT water for a minute or 2 to soften them up a bit and quickly push them in. a bit of grease on the hole of the drop links helps too. remember the open portions face opposite directions. they are a super tight fit. the hot water trick is great for firewall bushings too.
kevin
