-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Rough Running 2.0L Fixed (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/176758-rough-running-2-0l-fixed.html)
John Rogers 08-09-2004 12:37 PM
Our stock 1974 2.0L was running a little rough and it had new plugs, wires, cap, etc. Fuel pressure was 30# and capacity was fine. I pulled the injectors and found #1 had lost the plastic tip and was loose in the seal and you could see where there was some blow-by around the injector. Put in a replacement with new seals on all injectors and the roughness went away!
