Bus 2.0L Crank
Will it work in a 914 2.0L..what will work...
I really would appreciate any help. Paul |
I did find the answer to the question...yes it will work. but is it exactly the same...or will the differences effect performance?
Hopefully not...and does anyone have one for sale or know how much one would cost? What year is best? Thanks, Paul |
I've read the 914 cranks are hardened, but don't know for sure. The bus crank I had ground wasn't hardened, it from a "GE" block. All years are about the same. Some of the latest one may have the oil splash modification. It is a groove cut into the rod to squirt the bottom of the piston with oil.
| All times are GMT -8. The time now is 09:15 PM. |
