F1BADUDE's Avatar
Originally posted by Acox914
cheapest way is use 914 stub axles, and redrilled 914 hubs
I think that's the route i will take. I winze when I see the pix and how thin the area is around the new holes but everyone attests to it's strength so I'll save the bucks and spend it on more brakes up front.
Thanks,
Old 08-31-2004, 04:42 PM
Jim Smolka's Avatar
For the rear of my 914-6 3.2, I used 901/911 tranny drive flanges, a custom made spacer (I have these available), early 911 CV's, early 911 stub axle, 911 hubs and now some monster NASCAR style 12" rear rotors and calipers
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-31-2004, 05:05 PM
F1BADUDE's Avatar
What do you have up front?
Any problems with rear lock-up with the bigger rear brakes?
I bet it stops real nice.
Old 08-31-2004, 05:13 PM
BURN-BROS's Avatar
I would do what Jim did or the original 6. I think drilling rear hubs are dangerous for street. For racing, no way. Someone posted awhile back that the bearings that are in the front rotors will see a great deal of heat.
If you go 911 front suspension, choose 3.5 inch caliper bolt spacing for either S,turbo, calipers(a's too I think).as a rule, S calipers are good for 2000 lbs and 200 h.p. I got a great deal on my complete 911 suspension so look around and grab them when they come up.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-31-2004, 05:54 PM
mike mueller's Avatar
well, this has been discussed here and currently right now at 914club.com....so far not 1 person has seen a failure from redrilling the rear /4 hubs....street or race and I know a few cars that are running slicks that are much wider and sticky compared to any tire the factory knew of 30 years ago
of course I like Jims method, the more bolt-on items the better since replacement is much easier if you need to do some R&R in the future........
'73 914, 1.7, with Boxster transmission in the future?
Old 08-31-2004, 06:03 PM
BURN-BROS's Avatar
I know people do it, and their cars do not suddenly burst into flames after they do the mod. It still won't change my view. For a couple of hundred bucks you can get the 914/6 stubs. I got front and rear 911S suspension for $200.00 (praise to the recycler!). seems to me that this option is hard to beat.
Burnham Performance
Old 08-31-2004, 06:20 PM
Jim Smolka's Avatar
For the front of the 3.2 track beast is a 911 Carrera setup with Turbo Tie rods. The brakes are huge 13" rotors with NASCAR calipers. Brake bias is adj with a dual MC set up that is mfr from the stock pedal cluster. The 2 MC's are mounted where the stock MC is located.
'81 SC 3.6 (Beast)
Old 09-01-2004, 03:04 AM
Send a message via AIM to jim912928
I went the 914/6 stub axle route (those ones from mittlemotor..got a good deal). I already had a set of 911 rear hubs...with the 914/6 stub axles everything just bolted up! No fit issues anywhere and I feel more comfortable (maybe it is only peace of mind) knowing all the parts are being used as intended.
Jim
80 911SC Targa
75 914-6 3.2l Conversion
58 Triumph TR3A
07 Harley Night Rod Special, 08 buell 1125R, 08 Harley CVO Springer, 09 Harley Iron
Old 09-01-2004, 07:42 AM
914 Geek
If you do drill the rear hubs, don't just tap them for bolts. Do it the right way--spot-face around the back of the hole and press in studs. They will be stronger than a threaded fastener, at least if you have that flat spot on the back for the "shoulder" of the stud to sit on.
Besides, then you won't have to mess with wheel bolts again!
--DD
Old 09-01-2004, 08:53 AM
F1BADUDE's Avatar
Will 911 front hubs work with my 914 spindles or do I need to buy 911?
Old 09-01-2004, 05:36 PM
Acox914's Avatar
Send a message via AIM to Acox914
buy 911
-Aaron
"60% of the time, it works every time"
Old 09-01-2004, 06:02 PM
F1BADUDE's Avatar
How about the camber plate. Will my 914 plate work wit 911 Struts?
Old 09-01-2004, 06:07 PM
BURN-BROS's Avatar
I think so.
Burnham Performance
Old 09-01-2004, 07:07 PM
cruiksdr's Avatar
Yup, they're interchangable. 914 A-arms work, tie rods, camber plates, etc. All you need is 911 struts /rotors/calipers and bolt up. As previously noted, You can choose between those with 3" spacing for M calipers (low end) of 3.5" for A, S or other Big Brakes calipers (high end). I went with the 3" because that's what I found when I was looking, but then upgraded to the BMW big brakes (not the best, but good enough for my needs and a major step up from 914 stock.
'73 914-6 3.0SC
'69 Jaguar XKE
'05 Colorado Crew Cab
Old 09-01-2004, 07:24 PM
F1BADUDE's Avatar
I need the struts because of the spindles? I was planning on buying new Bilstien strut inserts. I'm pretty sure I'm going to buy a set of 83 rebuilt calipers with very low milage rotors and high end pads.
I was going to buy a set of hubs elsewhere. Should i look for used spindles as well? It is about $400 more here to buy complete strut assemblies over just inserts.
Old 09-01-2004, 07:47 PM
cruiksdr's Avatar
You can't use 911 hubs on 914 struts. The spindle is part of the strut, so you need to find the complete strut assembly from the 911. Look on the classifieds here at PParts or on Ebay They're out there and can be very cheap.
L@@K: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7919506442&category=33590&sspagename=WDVW
Just what you need for $200
'73 914-6 3.0SC
'69 Jaguar XKE
Old 09-01-2004, 09:02 PM
