-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 2.0lt. engine missing (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/177691-914-2-0lt-engine-missing.html)
Dave at Pelican Parts 08-18-2004 10:50 AM
Actually, it should only change the mixture during the warm-up. I believe that the total resistance drops below the threshold where the ECU does anything to the mixture by the time the engine is fully up to temp--but I could be wrong.
I'd be curious to see if the resistor has gone bad, or if the wires or connectors had.
Oh, and if one plug wire looked suspicous, just replace 'em all. They should come in a set, right?
--DD
Tab914 08-18-2004 04:15 PM
I will replace them all. Just have to get them. Strangely enough the one wire was a spare that was in the shop. As for the missing, I now have one when car run much hotter. Should I try and adjust my mixture? Do you think that maybe the car is running a little too rich? I would love to be totally rid of this problem. Car runs awesome before getting that hot. Hard to say what the exact temp. gets to but it's when temp needle gets up to 3/4 of the guage. Any ideas??
Tab914 08-19-2004 11:39 AM
Still getting that when car is up there in temp. Could it be the throttle switch? Will try changing the points today a maybe fiddle wit the mixture. Anyone know where the knob on the ECU should be and/or the best way to adjust this? Any input is appreciated. Cheers, Dominic.
mike95125 08-19-2004 12:01 PM
Did you adjust the timing back to stock?
Tab914 08-19-2004 12:21 PM
Yep! reajusted timing as per the book as well as dwell.
Dave at Pelican Parts 08-19-2004 02:16 PM
The "correct" setting for the knob is "whatever it takes to get the CO level within spec". I forget the spec, something like 1.5% at idle. If you set it to where the pointer on the knob lines up with a depressed spot on the ring around the knob, the "idle" circuit inside the ECU is not having any effect on the mixture. (IOW, just the MPS and engine RPM and temp sensors are affecting the mixture, not the fact that the throttle is closed.)
A not-too-awful place to start the knob at is halfway between full-right and full-left. Make a note of how many clicks from the one or the other you start out, though, so you can get back to where you are--just in case!
--DD
robinaube 08-19-2004 04:16 PM
Check your cooling fan is clear. I've seen red rags twirling around inside. They will block the air flow thru the fan and make the engine run hotter.
Tab914 08-19-2004 05:03 PM
Not a bad idea. I allready found a fuse panel plastic cover in there when I was finding TDC. Should have a closer look.
Pritchard 08-23-2004 06:31 PM
If problem still exists...
I had the same problem a while back. I tried everything that I could think of (new cap, rotor, wires, plugs, trigger points, TPS, CHT sensor). I ended up going through two brand new sets of wires, two brand new sets of plugs, two brand new rotors and one new cap before the problem went away. Hopefully you are not this unlucky, but you might want to try new sets of parts.
Good luck.
Pritchard
Tab914 08-23-2004 07:19 PM
Hey Pritchard! In the process of doing that. The car runs better than it did but still get the missing at high temp. Waiting for some parts and hope that they will do the trick. Think I might take the relay board off and clean it up underneath or at least have a look. I'm probably reaching but what the hey. Thanks for responding, Dominic.
