TraDog's Avatar
dual weber 34 ict carbs
Hi guys. This is probably a simple question for you. I just purchased a set of dual weber 34 ict carbs for my vw sand rail. I know to connect the two inlets from the intakes together but where do I connect the vacuum lines on the bottom of the carbs to?
Thank you for your help and support.
Old 08-22-2004, 06:53 PM
I have 34 ict's. Mine are plugged up with rubber plugs since new. I can't tell you what they are for, but I don't think they are needed for a 914 application.
Old 08-23-2004, 06:30 AM
TraDog's Avatar
Thank you Tom. I appreciate your help.
I will plug mine and run with it.
TraDog
Old 08-23-2004, 02:26 PM
