-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   4 spring vs 6 spring clutch (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/180326-4-spring-vs-6-spring-clutch.html)
Markeydoo 08-30-2004 07:10 PM
Whats the difference between 4 spring and the 6 spring clutch
Mark
AaronM 08-30-2004 07:15 PM
One has more springs. :p
The stock 914 doesn't make enough power to really necessitate the 6-spring clutch. The extra springs just make the center area more robust, but it's not really necessary for the stock engine.
Aaron
Alfred1 08-30-2004 08:31 PM
From the Pelican Parts Catalog:
"There are two types of clutch discs available for the 914-4. The stock disc with four springs, and the early 911 disc with six. The 911 disc will give you a much better feel for only a few more dollars, and is a direct replacement for the 914 disc."
