Debate
Hi guys I was hoping you could clarify some thing for me. I have a 2.7l 6 I am going to use in a mid engine aplication. The question is can I just bolt on a 914 tranny using my existing fly wheel. I've heard that this can't be done my fly wheel needs to be changed I have run into someone who is adament about it can be done. whats the scoop?
Bruce
Old 06-01-2000, 05:31 PM
To mate the 2.7 and your 901, you need an early 69 or older 911 flywheel. They are readly available, new for around $350.
The 914 flywheel mounting bolt pattern is different from that of the 2.7 crank....
JPIII
Old 06-04-2000, 08:25 AM
RETIRED
Joe Bob's Avatar
http://www.kennedyeng.com/
Go see these guys....they can make you a new flywheel and provide an oversize clutch package and cutout so you can handle all the extra horse power.
The older used 911 flywheels are overpriced and use a smaller clutch.
Old 06-04-2000, 08:46 AM
jabb's Avatar
Kennedy Eng Can also modify your existing
914 Flywheel to fit the 2.7 and 914 tansmission.
Joe A
Old 06-05-2000, 11:04 AM
